AlbatrossFPV
- Voron 2.4 R2
- Clockwork 1
- Afterburner
Hello all,
I’m having a rather specific issue with the Voron 2.4 that I built a couple of months ago from a kit by Spool 3D. As you should hopefully be able to tell from the video attached, the XY motion system is making all sorts of weird noises, such as creaking and squeaking. I am aware that the stepper motor noise is normal, but I don’t think that the creaking and squeaking noises are normal. A few more details that I have noticed in no particular order:
- It seems to be regular, as in, when the gantry passes over certain spots multiple times, similar noises are produced in the same spot every time
- The noises became gradually worse after building the printer, at first it was not at all noticeable, but now after about 300 hours of printing, it is quite pronounced
- I have rebuilt the printer completely once to replace all of the 3D printed parts with ones of my preferred color (purple!), which did not seem to improve or worsen the noises
- I have replaced nearly all of the flange bearings that the belts ride on in hopes of fixing the problem, but to no avail
- The noises do not seem to have any significant effect on print quality, although the print quality coming off of the machine is not exactly top notch either
- The A and B belts sometimes look like they will climb out of the bearings during movement, but never actually do (bottom right bearings looking from the back on B belt are especially prone)
- There seems to be a decent amount of wear on the belts since there black powder on the geared idlers and some of the belt sides are showing the internal reinforcement of the belt
- I do have a replacement set of belts, but I do not want to install them for them to simply wear away again, so ideally I’d like to find a solution before changing the belts if possible
- The XY motion system is completely stock (as described in the manual) except for the addition of the Klicky Probe mod
- The noises occur when moving diagonally as well as straight
