5160 problems
voron 2.4
Galileo
hey all, after a long break from the printer thanks to the kids spilling something and frying everything.... ive finally gotten around to putting together essentially a whole new printer... new psu's, board, drivers and pi
got some of the btt tmc5160 pro drivers and i get this message come up
TMC 'stepper_x' reports error: DRV_STATUS: 401f2000 s2vsb=1(ShortToSupply_B!) cs_actual=31 olb=1(OpenLoad_B!)Once the underlying issue is corrected, use the"FIRMWARE_RESTART" command to reset the firmware, reload theconfig, and restart the host software.Printer is shutdown
ive had a google and from what im seeing it could be a faulty driver... but surely not both?
hoping ive just missed something in the setup
cheers all
Well, lets see your config. Also what MCU are you using?
Could have sworn I attached the klippy log, not home atm but I’ll put it up when I get back, octopus pro 723
Everything’s pointing to wiring but I’ve gone over and over it and recrimped a couple times now to be sure
me again, getting same issue with a different board, running a kraken while i try and figure this out and same thing happening
pretty sure its not the wiring because i had to recrimp for the kraken and tested the ends for continuity so im sort of stumped
hope someone can help
  • klippy.log
hey mate, been flat out... yeah i still cant get it going hey
new motors even arrived so ive thrown them in... literally everything is now brand new and the problem persists
has to be config then... i just cant see it
save creating a new thread im just tapping onto my old one
since last post ive recrimped and was overly anal about getting them right, noticed krakens pins for a1a2b1b2 were different so swapped them over
tried a whole range of run current
every change to config ive been able to get my hands on... and still nothing
trying atm just at 24v 350w for the motors
psu reading 24 volt at the board but could it still be a dud psu you think? otherwise what could i be looking at?
just thinking now that maybe its the bootloader has the pins different but ive tried both the one from btt and vorons github so still not sure
a couple of logs and printer (1).cfg is the current one if anyone would kindly see what they can think of... best case scenario i get to facepalm myself
