- Voron 2.4 R2
- Clockwork 2
- Afterburner
Hey all,
Just completed building my voron with the help of a buddy. (He built most of it) he has built 5 machines so far.
The issue I’m having is in the X axis, I am getting a very faint vibration indicated on the print surface. The Y axis is super smooth. If I rotate the part at a 45 degree, the issue moves to both sides of the cube.
In the image below I have printed the same exact part with same settings but I just changed the orientation 90 degrees. I checked the frequency of the “wiggle” and it doesn’t appear to be the same pitch as the belts.
My thoughts are linear rail choppiness would be causing the issue in only the X axis. I tried packing the bearing but it didn’t seem to help
Thoughts? Ideas to try?
