- Voron 2.4 r2 300mm
- Clockwork 2
TL;DR: What is the maximum safe continuous bed temp for the stock voron 2.4r2 design using magnetic PEI sheet and adhesive that comes with the bed heating pad?
I was unable to find this on voron 2 guide.
I got a voron 2 300 kit from voronkits.com and trying to print ASA (polylite) in an enclosure. This stuff will not stick to the bed unless the bed is AT LEAST 110C. I started reading a few things that has me concerned, namely the adhesive on the bed heating pad (The kit came with Vivedino 110V 450W, NTC100K B3950) can break down at 100c, and it did have adhesive I used to stick to the aluminum plate, even though I also secured it with high temp RTV silicon.
Second is the adhesive for the magnetic sheet which somewhere on voron's website claims many can have a max temp of 70C. I really want to be able to print a variety of filaments without worrying about dangerous fumes.
So far, I have not smelled anything and have been printing at 115 / 110C for a few days now, but still want to make sure I'm not exceeding limits.
