What makes a Voron a Voron?
So , before I embark on my 2.4 build I thought I would do a warm up and convert an old printer to a Switchwire. It would be repurposing an existing unit, an Anet A8, and sort of be a dry run on what tools and supplies I may need for the 2.4 build, and can anyone really have enough 3D printers?
I was going originally to upgrade my Prusa MK3S+ to a MK4, and use all the removed parts to upgrade the Anet A8 to a "Prusa MK3S+", but didn't see that as cost effective. Then I found the Switchwire mods , and it seems everyone is taking other printers and making them Swithwires, so why not the A8?
So, the bad.... it's an old Anet A8
The good (maybe), it was upgraded to the AM8 metal frame with 2040 extrusions.
I did find one other A8 "upgrade" on github, https://github.com/maximilian-foerg/AM8-Switchwire-Mod but it had me asking, what makes a Voron a Voron? Is it the tool head? Linear rails? Core XZ/XY configurations? is it being enclosed?
So, my tentative plan, Strip the AM8 and check for squareness. I then need about $300 in electronics; power supplies, control board, RasPi, Prusa type heatbed and Y carrage (not using the Anet carrage and heatbed, as I want to use my exsiting Prusa flexible build sheets). I thought of using the STL files from the above Switchwire mod, but I think I will loose some performance and accuracy by re-using the Anet linerar rails. I also thought of using a Prusa MK3S+ extruder and hotend, as I can print the parts and utilize the same consumables and spares as my real MK3S+, but if I have to mod the carrage mount I might as well go with Voron supported tool, such as the Stealthburner, so many option.....
So...... What makes a Voron a Voron?
