RocknRolla
 - Voron 2.4r2 (Formbot as a baseline)
 - Galileo
I am working through merging the Voron 2.4 example config with the M8P v.2.0 and EBB SB2209 CAN(RP2040) sample config. This is a Formbot kit with Moons motors, When plugging things in, I used the pins and ports recommended in the documentation for each component.
If anyone can link to their working printer config for a similar setup, it would help loads. The main thing is the motors and stepper but in case it is relevant, here is my full build:
- Formbot Voron 2.4r2 350 kit as a baseline
 - Manta M8P v2.0 with CM4 (eMMC)
 - EBB SB2209 CAN(RP2040)
- Manta and SB2209 communicating by USB-to-CANBUS Bridge)
 - Galileo 2 Extruder in Stealthburner
 - Physical switch X and Y-endstops
 - ChaoticLabs CNC Tap V.2.0 as Z-endstop
 - Phatus Rapido HF w/PT1000 2-wire thermistor
 - BTT SFS V2.0 Smart Filament Sensor
 - Nevermore (and removed standard exhaust)
