Several boards also have a dual output channel that allows you to two motors in parallel off of one driver. Not sure if you would ever need to run them independently, but if not, that may be a quick and easy solution. (I know that the Octopus boards definitely have this!)How hard would it be to write a script to allow a 2nd (bowden) extruder to mirror my main (stealthburner) extruder's movements at the same time?
Could I simply follow this?
Oh crap! I've been planning to get started on this project today, as I'm finishing my 2.4V2 conversion(x rail) and TAP install!Several boards also have a dual output channel that allows you to two motors in parallel off of one driver. Not sure if you would ever need to run them independently, but if not, that may be a quick and easy solution. (I know that the Octopus boards definitely have this!)
just need a little something to assist with getting TPU through the tube, since I'm not really keen on building a top-loading spool holder to warp my extrusions.Hey Laser, I am curious what you are trying to accomplish? CW1 and CW2 have a lot of push/pull force.
I run a 4KG or 9LB spool on the back on my V2 with no problems.
