Ho-whizzle
- Trident
Hello,
I accidently damage the cable that connect the input shaper ADXL345 module, I searched online and I have found many (in the uk) 8 pin 0/5mm FFC ribbon cable but none of them reach a 1 Meter in length! Any one where I can purchase a 1 meter length cable or will I need to purchase a input shaper unit for the sake of a cable??
							 thepihut.com
					thepihut.com
				FFC Cable - 8 Pin, 0.5mm pitch (works with Flick Large)
Flat Flexible Cables! This one's an 8 Pin, 0.5mm pitch cable, with same-side connectors and it's 200mm long. It's designed to interface with the Flick Large Board but can be used for other applications which require an 8-pin 0.5mm pitch cable.
				 thepihut.com
					thepihut.com
		 I've since switched to toolhead board ADXLs on e.g. EBB36 toolhead boards.  KUSBA usb accelerometers are another option (don't get the 'Pro' version though).
