Question Belt tension problem, z-axis mechanism
Rede
Voron 2.4 350 rev.C
Hi, I have a problem as per the title with the tensioner of the z motors, as you can see from the video, when I go to put the lever in position the belt remains too loose and causes me problems. In the video the white piece is made of pla printed on a machine calibrated to perfection, but I also get the same problem with the ABS part. Depends on what? The Voron is an LDO kit and the belt is a 188 tooth GT2. Sorry if this has already been asked but I didn't know how to find it.
If it is not slipping then it's probably fine. If it is slipping then just pull it tight and tighten the bolts, you should be fine as long as the tension is about the same.
