ReXT3D
I am curious if anyone has investigated the magnitude of change in belt tension vs. chamber / frame / component temperature?
I noticed on my recently built 2.4 that there is a very significant increase in belt tension as the chamber heats up. While this is to be expected, the magnitude of this increase was a bit surprising to me. For example, the AB belts on my 2.4 are nominally adjusted to approximately 1.7 lbs (~100 Hz @ 150 mm) at room temperature (21-22 C). When the chamber is heated to just above 50 C, the tension increases to nearly 3.5 lbs (~145 Hz).
Note that I reduced the initial recommended target tension of 2 lbs because I was troubleshooting some very faint trace indications of belt teeth resonance in the Y axis.
