I'm really interested in going down the CanBus route for my Voron's, but I worry that there's a really key piece of information missing. Electrical and Electronic design is one of my hobbies and semi-professional life (I'm usually more on the IT side of cabinet building, but I work with my colleagues to produce electrical specifications). We typically work with 4-20mA devices (fieldbus wiring) and termination is usually ferruled end into spring terminals. All the boards specify the electrical side (Can_L, Can_H, PWR, GND) but don't have any indication of load (current or power), nor do they specify the terminal (some look like Molex MicroFit 3.0mm pitch, but there seems to be at least two other terminal types being used now).
Where can I find the power specs for the designs (e.g. max 5A load) so I can get the right size cables? where do I even find the spec for the connector? I've got my RS and Digikey accounts, but there's no way I can identify the right spec from vague pictures. It would really help if those products (I'm looking at you EBB 36) came with the right connectors, or at least told us what connector they used, so I could order them in.
Is the EBB 36/Klipper U2C open source? or is it a closed design somehow? Googling around and I don't find much more than a few manuals and some instructions about what needs connecting to what - doesn't tell me what's in the box, or what connectors I need in order to use the damn things, or the kind of cabling to order to meet the power needs and have a safe umbilical that isn't going to melt/catch fire on me
