Can you provide a starting printer.cfg file that includes the needed information for the Nitehawk toolboard? The printer.cfg file that you list on github specifically lists configuration settings for the extruder, endstops, thermisters, etc. but if you use the Nitehawk toolboard all of that stuff needs to be reconfigured. Should I be adding the info from the Nitehawk-SB.cfg file into the appropriate [extruder] sections of the printer.cfg file OR should I be commenting it all out and then referencing a separate nitehawk-sb.cfg file at the end of the printer.cfg file? My full setup is as follows for when I DO get things working and then can maybe share a working configuration with others:
LDO Trident Rev. D
Nitehawk toolboard
Chaotic TAP CNC V2
Manta M8P V2 with CM4 eMMC
BTT HDMI7 screen
LDO Trident Rev. D
Nitehawk toolboard
Chaotic TAP CNC V2
BTT HDMI7 screen
