CNC Tap experiences
X11-35/2
Hi Guys,
I often get told to get a Tap instead of auto Z Klicky and want to give it a try.
Have you guys experiences with the CNC ones? Chaotic labs maybe?
Also: is there even a Cnc Klicky which uses the optical sensor, instead of an optical micro switch?
I'm open for your experiences and thoughts
Hello, the alu tap may have some advantages when it comes to rigidity. But choose the right one.While VORON team is very happy when manufacturers bring their products on market, they somewhat did not understand basic principles of why Tap is the way it is, and used methods which were deemed not working well during early stages of development. They use single MGN7 - not even MGN9 - rail, and no side stabilization in forms of 2 magnets on the sides. You will experience wobble, because regardless of rail preload, it's still a single MGN7 rail. The opto-mechanical switch is also unknown factor.
If you insist on CNC tap, I would suggest taking a look at design made by Vitalii - https://github.com/Vitalii3D-xyz/MetalTap he sells his on Etsy, but similar designs can be find with I think Funssor or Blurolls, maybe Mellow now too?
tl;dr: I agree that the ChaoticLab CNC Tap should not be purchased, at least not the current version of it.
The problem with ChaoticLab, from my perspective, mostly stems from the 'chaotic' customer support users are receiving from the company. One staff member will tell users that the Tap should absolutely not be disassembled at all for any reason and that the rail does not need any added grease, while another staff member will tell users that you should absolutely clean the rail and grease it but still that you should do this without disassembling it (which, in my honest opinion, is simply not effective). And these two staff members appear to work opposite hours from each other, so the answer you receive will bounce back and forth depending on the time of day. I have myself experienced this in their Discord, and watched it happen to others as well.
My personal experience is that I had to completely disassemble the CL CNC Tap to properly clean it, and even got some metal shavings to come out of it. ChaoticLab assured me that this was impossible and that what I saw come out were bearings, but I'd like to think that it is fairly easy to tell the difference between a flat sliver of metal and a round ball (as tiny as it may be).
After I cleaned and greased it, the CL CNC Tap felt a LOT better. I don't have a lot of hours on it yet, but it has not developed any side-to-side slop for me as of yet. I should note that when reassembling it, I did add blue threadlocker to every screw to hopefully avoid some of the issues other users were reporting.
Here is an experience with CNC Tap that bit me last weekend. I've had my Voron for about a year and a half, but only installed the CNC Tap a couple of weeks ago. This weekend I was changing nozzles with one of the hot ends that offer a "one handed nozzle change" and felt a snap and the whole toolhead was now wobbling around. After taking the tool head and the CNC Tap apart I discovered that the linear rails are fastened to the Aluminum back plate of the CNC Tap by two M2 bolts. I discovered that the bolts were not long enough to engage the full depth of the threaded Aluminum hole, so the torque from doing the nozzle change was enough to pull the bolt right out of the holes destroying the threads in the process - Ugh. I do understand that they had specific dimensions they needed to hit so that the next standard bolt length was probably too long to fit so they went with the shorter bolt and hoped for the best. I did take longer bolts and ground them down to the perfect length and temporarily got the machine back together, but it's still unacceptably weak because I still only have half a hole with useful threads - just the back half now instead of the front half, sooner or later it's going to break.
I contacted ChaoticLab about replacing the CNC Tap. When I get the replacement I plan to swap in the longer bolts from the start and hopefully I'll never have an issue again, but so far their response has been just use longer bolts now and we'll give you a credit you can use towards a future purchase. Not an acceptable answer because I still have a thread issue and because unless they come out with new products, there isn't anything else I foresee needing from them - my Voron is pretty much modded as much as I envision now.
Did you by chance measure them after you ground them down ? I just received mine today and don't want those issues if I can avoid them.
Hey guys just received a V2 CNC from ChaoticLab and all the M3 holes are tapped really loose. See attached video. I have contacted customer support and they have replied with "This is normal. The metal threads will leave a slight gap. This gap requires axial pressure to eliminate."
Sounds like BS to me as I can't see why something would be engineered with such loose threads on purpose?
Does anyone else have a V2 with the same 'Issue'?
Been using the Chaoticlab CNC Voron Tap vor about 9 Months now and so far, very pleased with it except for the fact that they don't ( or at the time of my purchase didn't ) seem to be applying Threadlock to the Screws holding everything together which today almost resulted in an eMail to their support asking for a new Rail/Carrier with the evidence of a recording showing the issue.
Luckily, I decided to review the 4K Footage once more on my 77" Screen before sending the eMail off where I noticed the wobble not coming from between the Rail and Carrier but the Rail and Part it mounted to because of the Screws having come loose since they didn't have any Threadlock applied to them which I've now fixed.
So, yea... Except for that solvable ( and preventable ) Issue I'm very much pleased with it - Much more than I was with the 3D Printed Tap that just wasn't rigid enough.
@Gadjet:
Yeaa... Mine doesn't do that... 🤔 Also doesn't seem right to me - Are you using the appropriate Metric Screws? 🤨
Hey all,
Wondering if any have ran across this issue. A couple weeks ago my printhead came down hard on the bed, made a lot of noise so I hit Emergency Stop on my 2.4v2. After rehoming and at the Zprobe it crashes again. Something odd I noticed, the gantry was almost touching the bed... Somthing was awry.
SO, I take apart the PH and moving down to the Chaoticlab Tap v2. Remove that from the X rail carriage and turn on the microscope. I see this:
I originally ordered this Tap V2 July of 2024. I installed the Tap on my machine in July 2025 before I got the klipper kinematics config straightened out, yaknow dumb stuff like homing directions properly set and sensorless homing configured properly, etc.
So, doing what I do, everything working awesome for about 3 months. Then this bed crash a couple weeks ago. SO, I intend to send an email to chaoticlab support. That was a challenge finding their email address. I run across some reference to them being owned by BIQU so I send an email to their tech support, including these pictures as well. BIQU responds they are on vacation/holiday and I should try again tomorrow. No joke. Try an email again tomorrow.
You'll notice from the pictures that the retainer tab is completely sheared off. Like it was snapped clean and the Omron sensor (genuine) EE-SX4320 is cracked. There's also a blown out 0.1u ohm resistor blown on the PCB. Presumably the cause of the initial crash. (I'm always finding the small things cause the biggest problems)
So I did, I emailed again the next day, no reply for 24 hours (china time). I get an email back asking for my order number (amazon) so I provided it, wait 24 hours. Reply comes back from BIQU: (paraphrased) You're out of warranty because date of purchase was , unable to process warranty claim. Timespan: Oct. 6 through Oct. 8th. NO reply from support@chaoticlab.xyz yet.
Anyhow, thanks for reading. Just an FYI to a possible consideration of a design flaw or oversight.
If anyone would like to discuss... feel the freedom.
"sincerely" hehe
@natron734 This is what happened with the first ChaoticLab CNC tap I ordered. The tab snapped off before I had even completed calibration, so I was within the return period. I did still email CL first to see if they had any feedback -- I never got a response, so I just returned it for a replacement. The second unit is extremely sloppy, even after re-applying threadlocker to every screw. Again, I got no response from CL so I did what you did and reached out to BIQU, who asked for a video and simply said that was normal.
I don't experience better acceleration or quality with the CNC tap vs. the printed tap. I couldn't recommend this to anyone unless you, like me, just had a broken printed part and no other printer that print ABS/ASA.
@steeb
I tried to drill out a 1.6mm hole, tap a 2mm thread for a pan head cap screw to replace the broken retainer tab. I also successfully soldered the 0.1u resistor and a new Omron EE-SX4320, actually several. And let me tell you, getting that sensor accurately and precisely lined up was a pain. As it all turns out, the 2mm PHCS needed to be precisely shaped by hand micro-file, into the form of the tab allowing very little tolerance. There was a lot of time in the midst of filing the screw into shape. During that time I ordered the Vitalii 3D CNC Tap. It took 6 days to arrive. One Saturday, I went to my local library branch to print the few plastic bits needed to complete the Vitalii CNC Tap since my printer was down. That took me <2h printing time and I got to use a Prusa Mk4S for the first time.
All in all, I would say the Vitalii is a more robust and serviceable TAP implementation. Chaotic Lab certainly has gained a new meaning for me. Chaotic, indeed.
Congrats, CL - a thoroughly disappointed customer who will try very hard not to buy anything from BIQU/Chaoticlab again unless they review and dramatically improve their customer service. The time spent going away from an industry leader like BIQU has proven to be worth it. You would be well advised to understand that alternate solutions are not hard to find in this marketplace. Someone will gladly eat your lunch.
"Sincerely"
