Hey folks. I have an elusive "creaking" sound from my Stealthburner toolhead, and was hoping the experts might have some advice for my troubleshooting process.
The noise really does sound like a "creak".. like walking across an old wood floor kind of a noise. I wouldn't call it a "tick".
The printer has about 11 hours of print time, and the noise is new.
Things I have tried or checked (not necessarily in order):
So that's where I'm at. Based on #13, I think I can also rule out the bearings on that shaft. But the cause of the noise is a mystery. My only thought is that the drive shaft might be slightly asymmetric or non-concentric, but that wouldn't explain why I am only hearing the noise 11 hours in?
Any thoughts would be appreciated.
- Placed a mark on the extruder motor shaft: It turns smoothly and doesn't appear to be skipping.
- Checked E motor temp - hardly even warm to the touch.
- Extruding while stationary: The noise continues, so A/B/Z issues are ruled out.
- Reducing extrusion feed rate considerably & raised nozzle temperature: The noise continues, so not beyond volumetric limits
- Manually fed filament with extruder drive idler disengaged: Filament flows easily, so not a nozzle clog
- Adjusted the E motor gear lash: Verified that the large plastic gear can be moved back and forth with a slight amount of free play
- Removed idler arm and lightly sanded the sides to ensure it isn't binding against the CW2 housing: No change, and it moves freely
- Adjusted the extruder motor drive current: Default was 0.5A, tried as low as 0.2A and as high as 0.7A with no change to the sound
- Verified that there was no debris in the teeth between the two filament drive gears
- Verified that there was no damage to the teeth on the large white gear
- Adjusted the internal drive gear gap screw: makes no change throughout the whole range from all the way in (not making contact) through being out far enough that the drive gears no longer grip the filament
- Adjusted the tension knob all the way from fully in to falling out: No change
- Changed the limits and extruded very long distances: The creaking noises appear to repeat and coincide with the same spots on the extruder shaft with the long gear
- Checked with the idler disengaged entirely: the noise persists.
