Extrusion or bed level? Trident 300 build
evan
Hello all. I have a LDO Trident 300 which I have built but have never been happy with how it prints the first layer. If I print a small 30mm x 30mm first layer box at the centre of the bed, the spacing of the lines is uneven. Usually one half of the square has gaps while the second is close to perfect. My first thought was uneven extrusion so I disassembled the extruder and found the gears had been rubbing on the printed parts. I decided to upgrade to cw2 so purchased a new pancake motor and printed the new parts. I now have that up and running but am having the same issues. I then decided the inductive probe may be the issue so printed and installed KlickyNG. No luck, same issue. I have tried variable bed mesh also without any luck.
I guess I am looking for another set of eyes so to speak. I'm at a loss as to where to go from here? New extruder maybe? Anyway thoughts anybody? Cheers!
Really you need to measure to see what is out of square or flatness. A machine shop could do this or you can replace the extrusion or rails. Maybe you can shim the bed under the build surface with some tape?
Did you set your “rotation distance” correctly for your Z steppers in your printer.cfg? I had similar problems with my Trident until I realised I’d set my “rotation distance” to 8 instead of 4. (Check the specs of you Z stepper motors that should have come with your kit.) Once I resolved this everything started to print as expected.
Double checked. Mine are TR8x4, 1.8 deg steppers. They are LD0-42STH40-1684CL350ET(VRN) steppers which if I am correct should be;
rotation_distance: 4
full_steps_per_rotation: 200
Thanks Hot Toddy.
I did a bad job of explaining my thoughts above - what I meant was the hotend and/or extruder are extruding inconsistently. I am not sure if that is how you read it or not. However, if my aluminum extrusion or rails are warped what would be the best way to correct those? I have seen titanium backers and carbon extrusions online.... would you know if they help much? Currently I have the LDO kit stainless steel backers in all of my rail extrusions. Thanks!
Frankly, I doubt that the extrusions or rails are warped unless the quality was horrendous to begin with. I would suspect that the build plate may be more of an issue than anything else. So many of these vendors talk about cast plates but in reality, I think they are just plate aluminum that is machined "flat." By looking at your bed mesh, you possibly try a very small shim on the right front corner to see what happens.
Thanks for the reply! I should have posted a full bed mesh but was trying something with a smaller print. Sounds like a good idea though. Certainly worth trying before rebuilding the x & y or spending too much on parts. Cheers!
Do a full bed mesh to see what the whole bed looks like. From that small sample, You might have a crooked Y extrusion. Check the position of the ends of your Y extrusions.
Hi claudermilk. Yes, the full bed mesh reveals more, which I don't think can be fixed by shimming. Sorry, I forgot to save the image so can't post that. I think my best option is to rebuild the x and y gantry. I'd like to add the pins mod and maybe the rama idlers while I'm at it. What do you mean by checking the ends of the Y extrusions? - do you mean for level?
I don't think you need to rebuild all that. It looks like the left rear Y extrusion is a bit low (someone correct me if I'm wrong). Loosen that and get it to exactly the same distance from the top or bottom of the main frame and re tighten. I ran into the same issue with my initial build. I had to adjust my rear right by 0.1mm and after that my mesh came out much more even.
Basically, check the measurement on each end of both Y extrusions and make sure they match as close as you can get. Some time spent here will pay off when you get back to running a mesh.
Ok, sounds like a better option. I thought my ocd had kicked in over getting them exact when first building but it appears not. Cheers!
When I adjust my gantry corners, my goal is to set them so that they aren't the highest or lowest spots in my mesh. In your case, like claudermilk says, the rear left is sitting a bit too low, so I would loosen that screw and raise it .1-.2mm or so, retighten, re-Z-tilt (important!), and take a new mesh. Repeat until the corners are satisfactory. It's helpful to put a piece of tape to mark the starting point as a reference so you know how much you are adjusting.
Thank you LeOn. Really appreciate you sharing that. I plan on working on my trident this weekend. Will keep you all posted on how it goes.
Just wanted to say thanks to all for the suggestions to the problem I have been experiencing with my new Trident. I managed to achieve better results to the bed mesh on my printer. Initial test prints are much better to what I was getting previously. My only worry is the fact that I had to adjust the back left so much. Does that suggest there is something else out in the gantry somewhere?
Also - should I continue to tweak based on my results? :unsure:
Are you getting good print results? If you are, then I wouldn't bother--that's not a terrible overall range.
Unfortunately I spoke too soon. While overall the results look much better than before, the bottom layer / first layer is still inconsistent depending on where parts are placed. There's also an uneven or inconsistent extrusion issue at play I think, which isn't helping.
Silly question coming - but I was under the impression the bed mesh calibration routine would help in compensating for high and low area's of the bed?
Hm… A 0.101mm range on a 250mm bed is not terrible and should definitely be corrected by the mesh. Can you share a photo of first layer inconsistencies? Also, paste your [PRINT_START] macro or share your config file so we can make sure the mesh is active and not somehow being removed prior to printing.
Hi LeOn. I spent most of the day yesterday adjusting those extrusions. I could see an improvement for sure but based on the quality I get from my Voron0 I still wasn't happy. In the end I started the disassembly of the gantry. I want to double check everything and rebuild.
I will post my PRINT_START macro later tonight, I'd appreciate someone having a look at it.
EDIT - print_start macro below & photos of 30x30 patches. Extrusion widths seem inconsistent through the same patch?
[gcode_macro PRINT_START]
gcode:
{% set hotendtemp = params.EXTRUDER|default(210)|float %}
{% set bedtemp = params.BED|default(55)|float %}
M190 S{bedtemp} ; set initial bed temp and wait for temp to be reached
M109 S160 ; set initial hotend temp to 160 deg to prevent nozzle oozing and wait for temp to be reached
G28
Z_TILT_ADJUST
G28 ; home all axes
BED_MESH_CALIBRATE
G21 ; set to mm
M220 S100 ; set print speed to 100%
M221 S100 ; set flow rate to 100%
M107 ; disable fans
G90 ; absolute positioning
M83 ; extruder to relative mode
G92 E0 ; set extruder to zero
G1 Z0.6 X80.0 Y16.0 F6000.0 ; move to front left corner of bed
M109 S{hotendtemp} ; set & wait for hotend temp to be reached
G92 E0.0
G1 Z0.2 X180 E12 F800.0 ; intro line
G92 E0.0
gcode:
G28
Z_TILT_ADJUST
G28 ; home all axes
BED_MESH_CALIBRATE
G21 ; set to mm
M107 ; disable fans
G92 E0.0
G92 E0.0
M400 ; clear bufferView attachment 2544
Looks like a useable PRINT_START. Some suggestions (though none of this helps with an inconsistent first layer):
- The second G28 after the Z_TILT_ADJUST can just home Z with G28 Z to shave a few seconds.
- Any particular reason why you turn off fans with M107?
- The G92 E0.0 after M109 can be removed since extruder hasn't moved from the previous G92 E0.
Hm... The first layer kinda looks acceptable to me. The unevenness might be caused by a slightly tilted nozzle? is your hotend perpendicular? Do you see a similar thing happening with top surfaces as well?
