Tried their Refill PLA (not PLA+).
does not fit Masterspool design
Why did you do this eSun ?
This spool ships on cardboard roll that you cannot remove (the filament is wound too tight on the cardboard roll), which makes is unusable without buying eSUN's proprietary reusable spool.
Bought 3. One spool I tried to transfer to a masterspool with little success. Ended up having to manually re-wind the other two onto another spool to be able to use them,
I could not get even 2 meters out of the spool without it breaking in several pieces. Then the one spool that I managed to somewhat transfer to a masterspool
started breaking by itself overnight.
While re-spooling filament is not recommended usually, I never had issues doing it in the past.
+ when I was able to print with it, it was very consistent and easy to print with
- all of the above, will never buy again.
