Formbot Voron 2.4 R2 "Pro" 350 Kit build
Ytrahcodo
Just finishing up my first Voron build. Ordered the Formbot 2.4 R2 "Pro" 350 Kit direct from the Formbot site on 1/05 (US delivery) and received everything on 1/10.
Started unpacking on 1/11. The Formbot PRO Kit includes a lot of the current common upgrades such as TAP, Nevermore, toolhead PCBs, ACM deck, and 5" HDMI screen. So I also purchased the complete printed parts kit from Formbot since it included all the parts for this non-standard build. Printed in ABS/GF, comes in any color you want as long as it's red.
Had the frame assembled and squared up on day 1. I had some huge 24" x 24" thick rectified porcelain tiles on hand that are very flat, so one of these served as my frame build surface during the squaring stage.
Day 2 - 1/11:
Got the Z motors, idlers, and Z rails installed. Had to print the rail alignment tools first on my old CR10 before tightening the rails. So far everything was straight-forward, by the book.
Day 3 - 1/14:
Assembled the Clockwork 2 extruder and Stealthburner. This was a bit more complicated since the Formbot version of the SB has some differences due to their custom toolhead PCB and parts choices.
The gears they provided for the CW2 didn't mesh properly at first. The stepper pinion gear barely engaged the 50 tooth extruder gear. I don't know who they sourced this from but it's not right. Not the fault of the extruder case. I had to heat the shaft of the extruder gear to soften the grip on the gear enough so that I could move it on the shaft for better engagement. Not perfect, but it will do for now. I may end up replacing this later.
Day 4 - 1/15:
Got the gantry assembled, belts installed and adjusted, and the SB with TAP installed.
Day 5 , 6 - 1/18, 1/20: electrical installation and wiring.
Instead of a Raspberry PI, the Formbot kit comes with a Bigtreetech "BTT PI". I would have rather they left this out and saved me the the money since I already have a spare Raspberry PI 3, but I guess it's only about $30 anyway. The other downside is you have to use their custom BIQU PI image. This required a lot of fussing with the software that wouldn't have been necessary if it was a real PI. Also, I'd feel better, more secure, with a generic PI OS running on a standard board. May change this out later.
The wiring stage took the longest, due to so many customizations that I had to research. There's virtually no documentation from Formbot specifc to all the non-standard options that come in this PRO version kit. I probably spent more time researching the installation of these than I did actually on the assembly. Fortunately all the wire harnesses were pre-made, well labelled, and fit well - if you follow their style of component placement.
There's no separate 5V power supply in this kit. Both the Octopus and the BTT PI each have their own on-board 24V to 5V DCDC converters. The breakout board is a nice touch to simplify the gantry wiring.
It's been several days now of software installation, config files tweaking, and basic tuning. But it's running now, YAY!
After a couple failed attempts to get something to stick to the PEI build surface, it printed it's first Benchy, which came out nice considering I haven't done any input shaping tuning yet.
I'm already putting it to work making some parts for itself. Printed a wiring cover for the rear exhaust fan wires. Now starting on a real project in ABS that defeated me on my old CR10, and why I need a 350...
Hello! how did you solved the problem with printer cfg? i'm still trying, and if you have some extra photo with wiring of ldo board
Which problem are you asking about?
In general, I was able to find various configuration examples scattered around the web and patched them together with some edits for my particular printer.
Regarding "wiring of ldo board", this was a Formbot kit. It didn't have any boards from LDO.
Very roomy. I have the 300x300 and it is pretty tight in the electronics bay. Ditto on the research comment.
Ytrahcodo, is it possible for you to post pictures of where you mounted the Toolhead PCB and Fan Adapter PCB? Finally building the stealthburner and know they go on that assembly. Thank you!
First print with Polymaker ASA. Coming out very nice so far after 8 hours. About 6 hours left.
Very nice log on a solid build. I love to see you did the wiring neatly. It is a mess in my second hand machine. I will change this later when i am a bit more versed with the whole Voron world. I will also make a new pi with a proper voron based OS, mine is from a ratOS and then modified, it has a few non standard things in it as bagage and nobody knows how this might affect it later so....future work to do.
Great results too from your pictures.
How has it performed since the build? It has been a few months now.
@3dCase thanks. It's been performing well and very consistent. I still haven't done the resonance tuning with the kit provided accelerometer, so I believe there are still improvements to be made with reducing some ringing artifact. I've only printed with PLA and ASA so far. Print quality is very nice overall.
One thing I'm not happy with is a substantial apparent 'warp' of the build surface. The heightmap shows about a 0.25mm deviance range in a kind of saddle or potato chip shape. Don't know if it's actually the build plate or the gantry. The PEI build surface also has a bad 'oil-can' warp (bulge) so I'll probably replace that. It's still usable but makes first layer more difficult with very large parts.
After the initial run-in hours I did have to re-tension all the belts that had gotten very loose.
How thick is your aluminum tool plate for the bed? These are supposed to be cast and then milled which should result in a totally stress free bed. 0.25 mm sounds to me a reading error, or a interpretation error, or a manufacturing fault ready for warranty replacement.
Those graphs exaggerate the error for visual purposes, are you sure the reading is correct?
Hello there. Get yourself a printer config file from Voron github, upload to your printer board and rename it to printer.cfg
Edit printer.cfg using these instructions
search github and find someone who has the same configuration as you and compare his printer.cfg to yours
Good luck
