Galileo 2 vs Clockwork 2 vs Orbiter 2
Chachacha
With the announcement of the Galileo 2 I wonder what the benefits of it are over the cw2, and how it compares to something like the orbiter 2. I like the idea of having a planetary extruder as a novelty, but does it have practical benefits?
It's supposed to run smoother and is a little lighter from what I understand. I've been eyeing the Galileo for a while but never pulled the trigger. Just saw a built up example at the LDO booth at OC Maker Fair this weekend...and well, I'll be looking for parts kits in stock when they hit. It's a nice little package and will plug straight in where the CW2 sits.
I know this is an old thread but it is new to me :) Here is my experience with both. (in case someone else reads this later)
(TLDR version)
Galileo2 is easier to assemble than CW2. Galileo2 is 50g heavier and print quality is improved with Galileo2.
G2E (the version I built) is less likely to have issues from fasteners being too tight or something being maladjusted when assembling than CW2. (CW2 took a bit of thought when assembling, overtightening something is pretty common) CW2 uses some bolts as hinge pins and one as a place for the latch to hook onto. (those should NOT be very tight at all on CW2, the instructions jokes about overtightening at one point but it does not really stress this point properly or precisely) Nothing too difficult but I see quite a few people making the same mistakes assembling CW2.
G2E, on the other hand, uses some beefy pins that have no threads and there is no way to overtighten them. G2E has tight tolerance for the bearings. Make sure the print quality is really good. Lots of bearings and heat sets. Very nice design. Very good instructions on G2E. Read every word. It is quite good. Pretty hard to mess it up if you do.
G2 uses the same basic motor with a different shaft and 9T gear and planetary gears for max torque. (which makes it NOT the same motor actually)
G2 also uses a larger drive filament gear pushing against a bearing instead of the Bondtech style gears that mesh in CW2. This is all to improve print quality. (Mirage C has some videos on this on YouTube)
CW2 has a nice latch you flip open and a clean filament path. G2 has a spring tensioned tab that you hold down to load filament and also has a nice filament path. I do miss the latch but not much. Some people had CW2 latches break (maybe on the ERCF version only??) but mine never broke. The adjustment on CW2 involves an anti-squish thingamajig that is misunderstood and a thumbscrew. G2E just needs the thumbscrew turned in a couple of turns. (not much of an adjustment really) Again, G2E is hard to mess up. (except where noted in the instructions, again read every word, it is worth it and there aren't many words anyway)
Overall, it is easier to build G2 and there is less chance of having things too tight and no gear mesh to worry about and the manual is excellent. It is a bit heavier than CW2. (on my desk CW2 is 170g an G2E is 220 so 50g heavier) I do see more consistent layer lines on the machine that already has G2E. I do believe it improves print quality over the CW2. I printed cylinders before and after an the lines are just nicer when you shine a harsh light straight down the sides. (more consistent extrusion)
I bought a second G2E because print quality is important to me. (over lightweight and speed that is) 50g is more than I expected but it is worth it IMO.
CW2 isn't particularly difficult to build and the instruction are not bad. (I'm not saying not to build it)
My advice, if you want to build CW2, is to watch some videos on the anti-squish thingamajig, have some loctite on-hand. Assemble it with very little tension on the fasteners and pay close attention to what each fastener actually does. Watch for bending plastic and distortions it is easier than you think to overtighten certain things. Just remember that NOT every bolt is actually a bolt and many of them are NOT meant to hold this thing together. Mesh the motor gear with a little slop, it can't be so loose it skips a tooth but it should have back and forth play. Play with the assembled part like a fidget toy for a few days to a week with a small piece of filament loaded before installing. Make sure nothing binds and it works smoothly. Make sure it pulls hard when you manually turn the gear.
For G2E, just follow the instructions closely and you will be good. You can just install it after testing some filament through it by hand.
I don't see a good reason not to use G2E or the standalone version of Galileo2 if quality is important. Then again, if you are coming from CW1/Afterburner, you don't have to buy a whole kit if you go to CW2 which is nice. You need 2 x 50mm SHCS, 5015 blower and a few other small items. I don't recall what they all are but there are some upgrade kits available. Though RIDGA gears from Mellow or Bondtech do improve print quality on CW2. Otherwise you have to reverse one of the Bondtech style gears on the shaft. At that point, you aren't saving much. Just get Galileo 2. (my opinion)
I believe it is a lot like Orbiter 2. The designer of G2E was on the Steve Builds video and mentioned them being alike.
I'm interested in this a bit, because I have an orbiter 2, and it's wonderful, but it's not quite as well integrated in the stealthburner setup as I'd like.
I do have a canbus conversion in the works that will get me the ability to use the cool filament runout sensor it has, and maybe even the gcode button.
(TLDR version)
Thanks you so much for comparison
I just built a voron 2.4 and having problems with my CW2
I'm considering buying a galileo
Hi every one, silly question maybe, but i'd like to upgrade my CW1 extruder to Galileo2, and i would like to know if Orbiter2 parts can be used to build a G2 ? I do have a spare orbiter2 and i am thinking about repackaging it to fit my afterburner, or maybe an upgraded stealthburner.
Not a silly question. From watching the announcement livestream (which I recommend) it's mostly new parts. In particular the planetary gearbox is made from SLS (which is why it's considered an extended Voron design since it's not purely FDM 3D printed) and the motor is atypical. I recommend the LDO G2 kit myself. That means you can leave CW1 built should you need to use it. Any remaining parts that might transfer over would be things like fasteners and those are cheap.
I run a G2 on my 2.4 and can attest it's pretty great!
Since the Galileo 2 has been out for a while now, does anybody have a direct comparison experience with Orbiter 2 or Hextrudort?
Also, what is the approx. weight of the G2SA? I would probably try to find an SLS printed housing for extra precision and strength vs. FDM printed, that consistency is one of the advantages of the Orbiter 2 vs. DIY CW2 housings etc.
Actually I think I do! I don't have all your answers, but I have been able to compare G2 and OB2.5 recently. To be clear, I was very happy with G2. It's fairly approachable and produces stunning quality. I switched one of my printers to OB2.5 because I have a very specific PLA I need to use often which was causing jams. It seems to grind easily and I think I was getting heat creep with SB2 and Revo. So I decided to try XOL and while doing so opted to compare to OB2.5. So far I haven't had a single jam after several hours of printing various things, but it's a bit too early to draw a conclusion yet.
Quality wise, the G2 and OB2.5 are rather close when just assessing parts by eye and not pixel peeing as it were, but the G2 I think has a leg up there by using a single drive gear. Given the above, you have less grip with G2 vs OB2.5 (which is a dual drive gear setup) but can have more artifacts due to the mating of the gears never being perfect. In reality it's a small difference, but it's there.
This is apples to oranges too since I also swapped SB2 out for XOL and thus also moved to an umbilical all at the same time. So consider these loose conclusions.
I think if you don't need the grippiness of dual gears, G2 is certainly more open and is easy to build. I believe it works with XOL too if you wanted to go that route. I do find XOL more spartan but it is lighter and does seem to better cool the revo heatsink. But it looks quite a bit different from SB2 and less Voron-like if looks matter to ya. One nice thing about it is that you can use pancake toolboards. I'm using the newly updated NH36 and I tend to prefer this setup over using the side-mounted toolhead boards like on SB2.
I picked up a LDO Orbiter V2 for my build and its been working fine for all my needs. the best thing is it comes pre assembled with high quality gears and a fantastic extruder motor. it works great for my dragon burner.
Well..."best thing" and "Pre-assembled" may not go together well around here... :p
I have to say I very much enjoyed building my Galileo 2's (Stealthburner for the Trident & stand alone on a Dragon Burner for the V0.2). They both work great.
I hear you but getting access to good quality gears easily when I built mine was not an option. we had clone gears in our country and those were not meshing well with a few toolheads that I tried so had to go down the orbiter v2 route.
