Solved Help with Nozzle offset - After calibration print starts with nozzle too high
YCTJ
Voron 2.4 350mm
Hi all
This is my first printer based on Klipper so apologies in advance for any n00b questions.
I have built a Voron 2.4 350mm and having an issue setting the nozzle offset. My process to get this far has been:
Heat bed to 60C
Home
Run Quad Gantry Level
Run PROBE_CALIBRATE and make sure my nozzle offset is set properly with a sheet of paper and save config.
Run and save a new height map.
I have also run a probe repeatability check which passes.
After doing all of this no matter what, the print always starts with the nozzle a good few millimeters too high.
I have tried Prusa Slicer using the default voron configuration as well as Orca slicer.
Am I missing something or doing something wrong?
Thanks in advance for any help given.
T
Have you also tried Z_Endstop_Calibrate ? (Disclaimer) I bungled through all this to get my 2.4 running very recently so I'm not fluent, but I didn't see this in your description above. Not sure it's relevant to your situation.
Hi Chris
Thank you so much, this is exactly what I was missing! Coming from using marlin for years im still working out where everything is and what it does in Klipper haha!
Happy printing!
All the best!
T
Hi all
Heat bed to 60C
Home
T
Are you using TAP, Klicky, or other? I have same V2 350 with SB and TAP. I notice I have to stand by the Z fine tuning menu during my brim or skirt to make a .01mm adjustment or so
