Inconsistent z-offset
hendr1x
V2.4r2
Hello everyone,
I have an old v2.4r2 that I could never get to work right. Right now it is running pcb klicky and sexbolt. I'm getting inconsistent z off set...enough to make my first layer horrible most of the time. I'd appreciate any help as I am frankly completely out of ideas. I promise to be good at doing any actions/tests. I thought this was a mechanical issue though I don't know. I've rebuilt the gantry 3 times...rebuilt sexbolt at least 8, klicky 4 times. I've messed with Klipper/Fluidd a real lot too. The only way I can reliably print is by running PROBE_CALIBRATE every time. What I normally do is add a bunch of outer parameter lines on my prints and just dial it in manually over and over. I hate it so much.
Attached are hopefully all files you need. This forum doesn't allow uploading of cfg files so I renamed them to "-cfg.txt". The tests results are all called "-results.txt". auto-z-calibrate-results.txt is output from the Z_Calibration [ https://dangerklipper.io/Z_Calibration.html ] which I setup to do automatic z calibration. I implemented/rolled that back a few times now. I really wanted it / hoped it would help but now I am just at the stock/default z-offset setup. However, that leaves me with no method to show my issue other than my first layer being horrible every time I print.
Thanks for any help you can provide. If anyone prefers discord I am in "voron_2_help_forum_public" with the same title that I haven't gotten any help from unfortunately.
For (de)motivation, it seems a rabbit hole (I ended up writing my own code).
A possible way to debug is stacking a 2nd printsheet so the height difference will be obviously noticeable.
Note that my "2nd printsheet" bears the scars of learning things the hard way :-)
I'm not clear what that means. I was hoping to find some tests I could run to determine what is going on. I would have thought the qual_level or probe accuracy would have shown the issue.
Way back when I used Klicky, it was a little loose where it attached to the toolhead and giving my inconstant layers. Beacon does not physically touch anything and first layers are perfect every time.
Hello everyone,
Since I started using Revo PZ Probe and KAMP (https://github.com/kyleisah/Klipper-Adaptive-Meshing-Purging) I have had perfect first layers every time.
Peter
And I hope someone can give you a direct solution.
If not, what you might consider is Cartographer. While my Voron was still single-nozzle it was very straightforward ("touch" mode for Z offset detects via the nozzle). It's also extremely quick for meshing the bed, that alone would be reason to get it.
