- Voron 2.4 based on LDO kit
- Clockwork 2
Hello I just finshed my build of a 300x300 LDO 2.4 kit. I am having issues saving my z offset settings. I have run through the setup process on the Voron documentation site and I am able to complete Z_ENDSTOP_CALIBRATE process and then get a good print. I have saved the config and everything works fine even after a Klipper restart. When I do a firmware reset or full system power cycle my Z offset is off (its too high by about 0.25mm)
I have the standard out of the box setup with the Z endstop switch and the inductive probe. I'll upload my printer.cfg to this point.
Thanks in advance!!
Thanks in advance!!
