LOST COMMUNICATION
M1963
VORON TRIDENT
unaprijed hvala,
I assembled my Voron but I can't start it.
SIBOOR Voron Trident [lipanj, 2024.] CNC metalna konstrukcija 4AWD CoreXY
from the very beginning i had a problem with serial numbers.
no matter what i did it would always get the same uuid.
I finally got the result like in the picture above, but the printer still doesn't work.
prema uputama za instaliranje kartografa i ažuriranje moonrakera, ubacio sam navedeni kod.
Managing Updates via Moonraker​
In order to keep up to date with our latest Klipper software, please add the following config to the bottom of your moonraker.conf file.
Copy
<span><span><span>[</span><span>update_manager kartograf</span><span>]</span><br></span></span><span><span><span>savjet</span><span>:</span><span> </span><span>git_repo</span><br></span></span><span><span><span>put</span><span>:</span><span> </span><span>~/cartographer-klipper</span><br></span></span><span><span><span>kanal</span><span>:</span><span> </span><span>stabilan</span><br></span></span><span><span><span>podrijetlo</span><span>:</span><span> </span><span>https://github.com/Cartographer3D/cartographer-klipper.git</span><br></span></span><span><span><span>is_system_service</span><span>:</span><span> </span><span>False</span><br></span></span><span><span><span>managed_services</span><span>:</span><span> </span><span>klipper</span><br></span></span><span><span><span>info_tags</span><span>:</span><br></span></span><span><span><span> </span><span>desc=Cartographer Probe</span></span></span>
after that i have no access to the printer (second picture) except through PUTTY. please help.
datoteka moonraker.conf.
Okay..can someone explain to me how to access the moonraker.conf file via SSH (PuTTy) to delete the part of the code I inserted earlier. I explained all of this in the previous post.
thanks
