CyberBorder
I built my Voron 2.4 and after some problems it is now working correctly. Now I started printing with ABS and it was working fine but if I print for more than 3 hours I receive the following error. MCU 'MKS_THR' shutdown: Timer too close
I tried printing the same files in PLA and no problems. I have a Voron 2.4 with a MKS skipr and THR36 canbus. I thought about a canbus temperature problem but the values are not that high and it also has a passive heatsink. I leave the klippy.log so that you can see it and tell me about a possible solution.
https://github.com/CarlosTortonese/MyVoron/blob/main/klippy (5).log
I leave the log uploaded to github since it is very heavy and the forum does not allow me to upload it
Greetings
Greetings
