My V0.2 Formbot Build
robrob
V0.2 Kit from formbot, with a Phateus Dragon hotted and Self printed parts in Paramount 3D Beige ABS and Polymaker Sparkle Teal ABS accents.
Overall, I'm glad I built an LDO kit first, though the 0.2 is such a different beast than the 2.4. While I appreciate the build being small enough to work on on my well lit workbench, tight quarters are tight and unforgiving. For those curious Formbot provides zero documentation, it's basically like you sent a robot down the aisles of a parts department picking material from the BOMl. The savings are substantial, but the lack of support is A Thing, as well as some shoddy corners being cut– several wires had to be recrimped, and not enough hardware was sent to complete the panel and topcoat assembly.
The printed parts were the first thing I printed on my big Voron.
Of course I was impatient and printed them before working through ellis' tuning guide. They are mostly ok though.
The Formbot kit, unboxed. Note the lack of documentation.
Pre-build ritual.
IMG_7668-2.jpga
Extrusions laid out and labeled.
havent even started in earnest and the tweezers have come out.
Small plate is small!
Fun night in doing some rails. Linear rails.
The first of many nuts being pre-loaded. Finding a carriage that worked in these extrusions was a bit of a pain, and they are delicate. Print a lot. Like a whole lot. Also, tiny needle nose pliers are good fit for this build!
it helps to have a good QA assistant to check for squareness.
Bed attached. While I appreciate formbot tossing this part in, note that it's only THIS PART they toss in. Maple Leaf Makers video was somewhat helpful in figuring this mostly out.
I printed the STLS for the bed, the LEO wiring harness with neopixel I ordered from a vendor I am not gonna name still hasn't shipped the part after a couple weeks of waiting :/
Motors mounted!
Idlers idling.
Did I mention how much I love these tiny pliers? Also nit preloading. soooo much nut preloading.
Belted! Not as bad as I was expecting, though threading the second belt through the slot in the mounting piece was a pain; I had better luck undoing the first belt and running both through at the exact same time.
Bed prep.
Bed installed.
Boos looks unimpressed while I work on the extruder.
Strugglebussing my way through interpreting Moon label before I remember Motor schematics were the one docs Formbot thought to include.
Getting closer!
Panels, Door, and Topcoat in place!
This cable was killing me,. Initially I ordered a U shaped one on Amazon, but it didn't work out. Luckily, discord to me to hack up a USB cable and use Dupot connectors on the opcb pinouts.
Extrude jsut buzzing instead of extruding; narrowed it down to a bad/missed crimp at the Formbot factory. Grrrr
Since I had to get in there anyhow, I added a power supply cover to protect my paws (and route the USB cable); additionally, I added these 2mm spacers to the feet as the included motor bulges against the baseplate otherwise.
COMPLETE!
Situated next to it's buddy
I like this 2x4 table, and I amalso curious about the plastic filament bag you are using. Can you share what you are using?
Sure, they are esun filament bags from Amazon. Came with a little electric pump that’s pretty sweet. Couldn’t imagine using the manual hand pump version.
And thanks! The filament shelf’s are 1 inch wood dowels held up with brackets from printables.
I added some lights. Daylight on a matchstick, with MapleLeafMaker's diffuser. Came out pretty nice! They are super bright.
Couldn't deal with the dinky little screen. It was cute and all, but I missed Klipperscreen, and wanted the same UI as its big brother.
Canabalized the Pi Screen off my kippered Ender 3 and found a nice mount that worked great with the stock 02 skirts. IMG_7851.jpgIMG_7847.jpg
View attachment 2670View attachment 2671View attachment 2672
Motors mounted!
Idlers idling.
Bed prep.
No thermal fuse?
