Newer Prusaslicer ini?
Pichels
LDO 350 2.4
Hello,
I have a LDO 350, and I encountered a problem in fluidd, where it cannot open the file. The gcode preview does work. The virtual SD card path is set to ~printer_data/gcodes. I used the ini from github and changed the bed dimensions, but I'm suspecting that something has changed in the 4 years since that ini was released. The origin of the bed plate is correct in Prusaslicer.
Thoughts?
Are you talking about slicer profile? All major slicers now have VORON profiles built-in with reasonable defaults. Just run the add printer wizard, list VORON as manufacturer and select it printer you have. Adjust it as part of tuning to match your machine.
