Question Problem XY Homeing Check
todo77
Voron 2.4r1
Clockwork 1
Afterburner
I have a problem with the commissioning point XY Homing Check. In my case, the Y axis moves when I control X and vice versa. I have already checked the cables and checked the slot on the BTT Octopus 1.1 board. In the software, stepper B is configured to motor 0 and stepper A to motor 1 on the board.
However, I can then stop the respective reference run with the correct end stop. Does anyone have a solution to my problem?
You might have to invert the motor direction with a ! in from the the pin.
I have also tried this, unfortunately without success. I will now turn the plugs on the stepper directly. In other words, swap the stepper windings.
Hi, your X and Y motors may be swapped.
Check initial startup guide there is very handy diagram of how wrongly wired motors demonstrate and what to do:
