As long as your QGL eventually converges (ends without failing), you should be fine. A few mms (in X and y) here or there doesn’t matter - the important thing is to even out the height of four corners - their exact XY position doesn’t have to be accurate to a few mms.
Hi, if you take example configurations from VORON Github, they have all the necessary sections prepared for you. Just uncomment corresponding size, or copypaste it to your config.
Follow Initial Setup Guide on Docs page to determine position of your Z endstop. There is section dedicated for it.
