Question QGL gantry_corners and position_endstop
modsley
Hello. In my 300х300 build I have to set
[stepper_x]
position_min: 0
position_endstop: 295
position_max: 295
Should I also change
[quad_gantry_level]
gantry_corners:
That is now
gantry_corners:
-60,-10
360,370
Thank you.
As long as your QGL eventually converges (ends without failing), you should be fine. A few mms (in X and y) here or there doesn’t matter - the important thing is to even out the height of four corners - their exact XY position doesn’t have to be accurate to a few mms.
[stepper_x]
position_min: 0
position_max: 295
[quad_gantry_level]
gantry_corners:
That is now
gantry_corners:
-60,-10
360,370
Thank you.
Hi, if you take example configurations from VORON Github, they have all the necessary sections prepared for you. Just uncomment corresponding size, or copypaste it to your config.
Follow Initial Setup Guide on Docs page to determine position of your Z endstop. There is section dedicated for it.
