QUAD_GANTRY_LEVEL fails due very high Actuator Positions
Andrés
Voron 2.4 Pro Formbot
Hi guys,
I am building up a Voron 2.4 Pro Formbot. Now I am trying for nearly a week to fix the issue with my gantry level.
Switching wiring of the motors doesn't help. Now I have front left -> Z0, rear left -> Z1, rear right Z2, front right Z3.
WIth this wiring I am getting this result in the quad_gantry_level:
18:14 Aborting quad_gantry_level required adjustment 353839846697334189588480.000000 is greater than max_adjust 2.000000
18:14 Average: -116979654425515982323712.000000
18:14 Actuator Positions: z: 88278656459288212406272.000000 z1: -470819501122850171912192.000000 z2: -105080336047367392329728.000000 z3: 19702563008865418346496.000000
18:14 Gantry-relative probe points: 0: 4.766250 1: 4.661250 2: 4.998750 3: 4.905000
18:14 probe at 50.000,250.000 is z=0.096250
Does someone know how this large numbers are coming up?
Sometimes I see the probing runs some rounds and after each round the system tries to correct the z motors. I have the feeling in the worng direction. The result is after two/three rounds that the max_adjust fails ...
This is normally a symptom of not having your x / y movement configured properly, or having the z motors wired in the wrong order (which it sounds like you covered)
so when you're moving in x/y, is x=0 on the left? And y=0 at the front?
One potential issue I see is that your QGL points are in the wrong order, which can cause problems:
   50, 50
   250,50
   250,250
   50,250
They should be in the same order as the motors. Try using the values from the stock config (for a 300 size build):
   50,25
   50,225
   250,225
   250,25
(The Y positions are a bit different because QGL doesn't take probe offset into account.)
Thanks, for the fast answers!
I have change the points and set home_xy_position:50,25
I have to tell that I have tap probe. I have recheck all screws around the tap. Thought it hangs some where.
I have done some tries and got some error messages "No trigger on probe after full movement". Every time when I get this message, I am disabling motors and press the corner a bit down that I get a blue light.
I can not believe it, but after 4-5 rounds I got now a successful quad gantry. Second time ... work again! This really a bit weird!
Retries: 0/3 Probed points range: 0.002500 tolerance: 0.007500
I will keep it so and will go on to finish now the build!
Thanks for your help ... hope now everything will run now good!
   50, 50
   250,50
   250,250
   50,250
   50,25
   50,225
   250,225
   250,25
Hello, thank you very much. My problem was also solved in this case
But after a few rounds of the gantry level, the errors increase and this message appears
