LoSpo
Good evening ,
i have this leds in my stealthburner but the works random.
my leds:
www.fysetc.com
the file i try to change to make all things works:
github.com
my configuration:
my leds:
FYSETC Voron StealthBurner LED Kit NeoPixel RGBW Mini Button PCB Leds
Printed part Link:https://www.printables.com/model/642714-fysetc-stealthburner-led-carrier-for-neopixel-rain
www.fysetc.com
Voron-Stealthburner/Firmware/stealthburner_leds.cfg at main · VoronDesign/Voron-Stealthburner
Contribute to VoronDesign/Voron-Stealthburner development by creating an account on GitHub.
[neopixel sb_leds]
pin: PA8
# The pin connected to the neopixel. This parameter must be provided.
chain_count: 10
# The number of Neopixel chips that are "daisy chained" to the
# provided pin. The default is 1 (which indicates only a single
# Neopixel is connected to the pin).
#color_order: GRB, GRB, GRB, GRB, GRB, GRB, GRB, GRB, GRBW, GRBW
color_order: RGB, RGB, RGB, RGB, RGB, RGB, RGB, RGB, RGB, RGB
# Set the pixel order required by the LED hardware. Options are GRB,
# RGB, GRBW, or RGBW. The default is GRB.
initial_RED: 1.0
initial_GREEN: 0.0
initial_BLUE: 1.0
initial_WHITE: 0.0
# Sets the initial LED color of the Neopixel. Each value should be
# between 0.0 and 1.0. The WHITE option is only available on RGBW
# LEDs. The default for each color is 0.#
# Most configuration for the macros can be done by modifying the variables in the _sb_vars macro
# at the start of this file.
