- Voron 2.4.r2 Rev.C LDO kit
- Clockwork 2
Hi guys,
First of all i apologize for having to post all these questions, but if your new to this digging through all the available info isnt easy at all. People post their start GCODE but understanding it, and trying to make it work for my setup is very tricky. The LDO kit includes a klicky set, but i am not using that yet. I'm using the included Omron z probe.
I am having issues with my first layer sticking to the bed. I have a feeling this has something to do with my probing being off because of oozed filament. If i try to do babysteps to adjust Z there is allready enough loose filament on the bed for the print to go wrong. Another strange thing is, while heating up its oozing filament, but when it is supposed to lay it down, nothing comes out for a couple of seconds.
So now i am trying to change up my start Gcode to not heat the nozzle fully in the beginning, but rather have it heat up to about 150C, then do QGL and BEDMESH, then i would like it to heat up fully just before it starts to lay down the first layer.
Is there someone who has the time to look at my start GCODE with me (posted below), to try and get that going? I know below start GCODE does not do the things that i want, but when i make changes that i think are appropriate, i straight away get an error after the bed heats and it needs to move on to heating the nozzle to 150C. The error are:
13:25
Extruder not hot enough
13:25
Error on 'M140 S': unable to parse
13:25
I can print small things, but when it gets a little more complex all my prints fail. Driving me a bit nuts.
Cheers!
Pepijn
[gcode_macro PRINT_START]
gcode:
SET_GCODE_OFFSET Z=0 ; Start from scratch.
STATUS_HOMING ; SB Neopixel status: HOMING
G28
STATUS_READY ; SB Neopixel status: READY
STATUS_LEVELING ; SB Neopixel status: QGL
QUAD_GANTRY_LEVEL ; quad gantry leveling
G28 ; Home all axes
BED_MESH_CLEAR ; Clear all bedmeshes
STATUS_MESHING ; SB Neopixel status: BED MESH
BED_MESH_CALIBRATE ; Mesh bed level
BED_MESH_PROFILE LOAD=default ; Use the stored mesh.
G28
G90 ; absolute positioning
G1 Z20 F3000 ; move nozzle away from bed
#TUNING_TOWER COMMAND=SET_PRESSURE_ADVANCE PARAMETER=ADVANCE START=0 FACTOR=.0025
13:25
13:25
13:25
Cheers!
Pepijn
gcode:
G28
G28 ; Home all axes
G28
