Coyote
Trying to finish up my Voron 2.4 350mm build. I have completed some of the 'Initial Startup' through QGL with only minor fixable issues. I also installed Tap and it is working great. But the Stealthburner LEDs are not working. I'm using a 1-piece Stealthburner PCB and a Octopus V1.1 control board. I have the LEDs plugged into the PCB LED JST receptacle. I have the LED data line running from the PCB to PB0 pin on the Octo board and I set 'pin' to PB0 (pin: PB0) in the stealthburner_leds.cfg file. But the LEDs are not on. I tried adding a 100 Ohm resister to the data line as outlined by the "Stealthburner Neopixel Guide" but that did not work. I also tried using PB6 instead of PB0 on the Octo board but still a nogo. Before I start taking the toolhead apart to check continuity of the LEDs I thought I ask y'all for suggestions. I have tried to Google the problem but found nothing useful. Any suggestions?
thanks
thanks
