Zephyrus67
Not sure what is going on with this new Voron Tap + SB install.
I just installed Stealburner and in the same take I installed Tap.
Everything seems to work perfectly fine...UNTIL I want to do a print...
If I am preheating to 240C then when starting the print it is lowering the toolhead temp to 150C to be able to home and QGL.
When it is done with that it cancels the print with the message "Extrude below minimum temp" and "Extruder not hot enough".
if i instead starts the print job from a cold hotend state like 100C then it starts by heating up to 240C....THEN it cools down to 150C and going through the same erroring as mentioned before
I did the setup as told the both the SB setup instructions by copying the "stealthburner_leds.cfg" to the config folder..and that part works.
I also made the changes to the config file as mentioned in the "tap_klipper_instructions.md" from the Tap config folder.
how am I supposed to print?
