trident 350 Bed level issue
xinyuliu
voron trident 350
LGX Lite
No matter how I adjust it, the left side is higher than the right side
share my bed mesh data and print cfg
I use supinda probes on my other 2.4, using the duet system, it works well and can be a perfect first layer
The same super pinda is used on trident, and it is very bad with klipper firmware
Can you give me some ideas for adjustment?
  • print cfg.txt
    print cfg.txt
had the same issue. had even swapped beds because i was convinced the one that came with the kit was warped. it was not warped. the extrusions holding up the Y axis are not aligned. loosen the right side slightly, move the gantry manually up and down the Y axis a few times. run the bed mesh & see if it gets better. if worse, then the right is not misaligned, but the left is. do the same on the left & repeat until it's even.
your bed is quite level already. 0.155mm range is very good for 350x350. i would leave it alone. i would also recommend using beacon or cartographer for bed mesh. it is fast, very accurate, and very reliable in my experience.
Just as a test, put a 3mm shim under the back left foot of your printer and compare the mesh. A short stack of paper works fine.
I chased this for a while. I move my printer around. On one table it sits flat and the bed look perfect. On a different (rougher) table I need the shim or one corner of the bed looks high. If I rotate the printer on that rougher table, I have to keep the shims in the same spot.
