Question Unknown pin chip name scanner
alexally
Hello, I need help. I can't figure out the problem with Voron trident during setup.An error appears when loading the Klipper "Unknown pin chip name 'scanner"
I'm still new to assembly
  • EBB SB2209 (RP2040) CAN Board
  • MANTA M8P V2.0 Motherboard +CM4
  • Cartographer V3 - Standard Version with ADXL345
Taking a quick look, I would suspect it's complaining about the line cs_pin: scanner:PA3 in the adxl345 section. Which leads to the scanner section & the canbus definition. I'm not familiar with canbus setups, so that's as far as I can point. My guess is it isn't seeing the canbus.
