verify _heater
langerd
voron 2.4r2
hi,
my voron 2.4r2 has been working very well for about 6 months with stealthburner. all the sudden it would stop midprint and report adc out of range. i have replaced the hotend thermistor and heater cartridge. now it will stop mid print and report verify_heater error; the led on the sb would go out when this happens…
0. replaced the thermistor and 65w heater cartridge twice
1.checked the 2 piece pcb connector and wires for continuity all the way to the main board. i even went and solder the thermistor to the pcb.
2.performed a PID with 10% fan on many times
3.i have routed both thermistor and heater to new locations on the main board, and updated the printer.cfg accordingly
it appears from the picture that it cannot regulate the hot end temperature during printing but can sit idle for a long time without issues. any advice is appreciated
4.removed all connectors on the 2 piece pcb and solder wire directly to the pcb,
5.inspected and recrimped the hot end heater tube and thermistor wiring attached to the main board
still having verify_heater shutdown.
Do you connect heater and thermistor wires directly through chains? That's not recommended, those wires are not rated for motion.
What hotend do you use? Do you have sock on your hotend? You wrote you did PID with 10% fan, is this also fan speed you use for normal printing?
using a sock with dragon highflow.
yes the fan speed is what i used for printing.
i did isolate the issue to the thermistor wire thru the chain. i bypassed the chain temporarily and it fix the issue; rock solid thermal hotend regulation.
strange that you said the wires are not meant to be run thru the chains, how are others running their wires? what wire type do you recommend?
It's preferred to use wiring which can withstand constant motion, usually some with more (at least 19) strands inside, and either silicone or teflon insulation. Teflon is preferred, with silicone those chains can become very packed. I am surprised yours lasted this long if you really used heater wire as it is, for example probe wiring usually dies within first print or two.
Here is more information about crimping, wiring etc.:
Normally it's done that you cut toolhead wires at the toolhead, terminate with Molex Mictofit 3 connector, and then continue with chain wiring further, down to electronics compartment. Alternatively you can get toolhead PCB which simplifies it a bit.
the wire i pulled looks like teflon, 24awg, only 7 strand.
thanks for the advice. i will some 22awg silicon laying around i will try to snake thru the chain.
