- Voron 0.2
- Other
- Other
Hi,
I have a problem that I don't know how to solve.
I have a Voron 0.2 with a PZ probe in a Dragon Burner. I want to home the printer using the endstop and then probe the bed afterward.
Homing works, and probing works as well, but the mesh is about 0.5mm above "0," which results in prints being about 0.5mm too short.
When I print a 15x15x15mm cube, the X and Y dimensions are spot on, but the Z dimension measures only about 14.5mm. However, when I use the probe as my homing endstop, the cube comes out perfectly.
I hope you can help me.
Thx!
Thx!
