Having built 2 Voron 2.4's with the same issue I guess someone else might have it too....
On both of my V2.4's the xy joint cable bridge touches/rubs on the y-axis drag chain. I assume the generic drag chain I am using is maybe slightly larger than the original spec. But regardless if anyone else has this issue, here is a new version of the bridge which provides greater clearance in the event you have the same issue.
Here is a link to the part... replacement xy cable bridge
