- Voron 2.4
- Clockwork 1
I have successfully set up my voron 2.4 250mm today everything configured so far everything works as it should.
My problem with the print is a kind of Z error that occurs regularly every 3.2mm on the picture you can see more.
If you measure at the larger point, the value here deviates from the target, does anyone have any idea what I can do here?
Mechanically everything can be ruled out, I have already checked several times and the error is too regular.
Translated with DeepL
