Question voron vs bambu
EricE555
I have a Voron 2.4R2 300mm that I have used for about 4 years now. After seeing the results coming out of Bambu printers I recently bought a X1C also. I am amazed at the print quality from the Bambu. The fact that I can print on the Bambu at .2 layer height and come out with a print where one cannot see the layer lines is asounding. It looks like an injection molded part.
I have tuned my Voron in every way I know how but the quality doesn't match up with the Bambu. Should it? I mean, is it possible to tune the 2.4r2 to match up with the Bambu? Does anyone have 2.4r2 that matches print for print with the X1C?
p.s. I get that I am going to get a lot of haters by posting on a Voron forum but this is a serious question, not a troll.
You won't get any haters here.
But, the quality of the printer on a Voron is based on the user who built it. Let me explain.
I have an X1C as well and yes, it just prints amazing out of the box. In fact any issues I have ever had is usually my fault or bed adhesion issues, again, my fault.
The Voron being open source and have such a broad range of upgrades means its up to you to tune it well since every single one is different. I will say that from my Vorons I have had pretty decent parts but not great until I spent a lot of time truly tuning it. What I mean is I went through the Ellis Bible many times, and worked on my input shaping many times and finally got parts that I would consider better then the X1C. But agian, I spent weeks of my free time tuning where as the X1C is pretty good out of box.
I am not home now but I can try and upload some pics of tuned prints that you can't see a single flaw in.
If you want any help tuning post some pics of the issues and we can try and work out where the problem stems from and go from there.
Tuning bible https://ellis3dp.com/Print-Tuning-Guide/?mwg_rnd=1410272
Unless you use something like carbon fiber filament I can't see how any printer can hide 0.2mm layer lines. I can't see how that is physical possible without post processing.
All modern printers these days have similar print quality. I would say even an entry level printer can print similar quality PLA prints as a voron or bambu.
Some are have more fan and thus better for overhangs (stealthburner is quite bad).
But Bambu brings it all together: Tuned and updated profiles, solid hardware, easy to setup, automated calibration.
To get voron to a similar quality you need more fan, some decent slicer profiles, Pressure Advanced for every material you have, klipper resonance compensation.
After 4 years of printing, maybe your nozzle is not good enough any more. They have to be replaced from time to time. Also make sure your belts are the correct tension, and if you change the belts tension you also have to re-do resonance compensation.
I am retired so, yes, I have the time. One thing I am looking at is how heavy the toolhead is on my Voron vs the X1C. Am I going to have to make a bunch of changes to the 2.4r2 to make it that good?
The relevant parts are: G2E, Stealthburner, Mosquito HE, hardened nozzle, CNC metal XY Gantry joints, XY extrusion backers, ADXL (not permenently attached). I'll try a part I recently printed on the X1C so I can see them side by side. More to come.
I installed an upgrade that massively improved print quality on my LDO 2.4/350 : a Box Turtle. The open source equivalent for the Bambu AMS.
Layer consistency is night and day.
This thing simply compensates for the drag in the reverse Bowden. Despite the 3mm ID tubing, the CW2 does no like the 1 meter or so. BTW, had to reduce a bit the flow ratio in the slicer.
(I print ABS and ASA only)
Was wondering if I was the only one, and asked on the dedicated Discord : I'm not...
Been using it for 5 months. Serialized it by the end of 2024. Some pieces still are from the open beta.
Given that Voron is not a company, doesn't sell anything, and gives away everything that gets created, its hard to understand haters that do exist. It is just a bunch of people that love to design and build stuff.
  • Like
Reactions: mkl
You are saying a filament changer improved print quality? I think you had an issue that might be masked by the filament changer.
Of course it does.
Reason why such devices exist for non multicolor printers.
See Mellow LLL.
I was linked to this device by the Box Turtle developper when I asked if I was the only one the BT was improving print quality.
It's a closed loop. As soon as there's tension on the filament, the secondary extruder pushes some more.
Oh, forgot to say... Such a buffer (stepper based) is natively supported by the AFC Klipper Add On. Tested it. Works fine (with one lane, and no spooler motor)
Hi NoGuru, This might be explained by the fact "to print the BoxTurtle Extruders, it's recommended your machine SKEW needs to be calibrated - X/Y SKEW (Z/Y, Z/X also helps), else, you wont be able to assemble the Extruder Box and Lid. Like what happened to me. I was amazed at how bad my Skew was, but I thought my prints were solid. By initial BoxTurtle Extruder prints left me perplexed until I added my Skew correction. Since then I'm experiencing amazing prints with dimensional accuracy - best of all my BT Extruder boxes fit. Funny, Just building this BT project has helped me bump up my print quality. I'm on a fixed income though, I wouldn't passup an X1C if it bit me on the a$$. I hope that helped someone.
It's about extrusion consistency, it has nothing to do with skew correction.
Active buffers exist for two reasons : extrusion consistency and assisted load/unload.
Consistency : compensates for the reverse Bowden friction, that depends on the toolhead position, despite the recommended 3x4 PTFE. Larger printers do benefit from such a device : the SV08 max comes with such a device from factory.
There's also the Belay by Annex Engineering : https://github.com/Annex-Engineering/Belay?tab=readme-ov-file#purpose-and-how-it-works
Recently : the WISEPRO 3D Printer Filament Buffer (https://wisepro3d.com/products/3d-printer-filament-buffer) : buffer + infinite spool.
Yaaj, you said the Box Turtle massively improved layer consistency. For someone who might not want a multi-filament setup, are there any single-filament 'active buffer' solutions that could achieve a similar result on a Voron?
You can always add a bowden extruder in line with your direct drive. Lots of M4 extruder mods out there.
It seems the mentioned Mellow LLL buffer does that
The Filamentalist
Sorry for the late answer ! But you already got some.
There's also the Belay by Annex Engineering : It's a one way buffer, requires a extruder and some software.
You were right, I was having other issues than the crazy long bowden (4x3 of course)
My 2.4/350 reaches 70+ (summer...) and the CW2 extruder was slowly failing under the load and the heat from the motor. Failed after a couple of hundreds hours.
4th time I have to reprint it. First one was printed with eSun ABS+ (outdateed information about this filament). Second one with eSun ABS. Third one with Polymaker ASA.
Switched to a full CNC kit, got a Revo High Temp, reprinted the Stealthburner with Siraya Tech PET-CF, and annealed the parts. Crossing fingers.
