Upgrade from V2.4 350 built in mid 2021 => newest rev
carmamir
Voron 2.4 350
Clockwork 1
Afterburner
While waiting the INDX I am looking to upgrade couple things + re-print/re-install anything necessary.
Now new parts are:
- Galileo 2 kit
- Nitehawk-36
- Bambu Lab X1C hotend
- new AB belts from Gates
- new fans for new hole print head.
I assume I need to get SB for Galileo + either create my own mix for Nitehawk-36 or find appropriate.
But what about A/B gantry parts? Any upgrades since 2021 or should I just re-print revision from 2021 that I have used to build my Voron...
I will be reprinting A/B at least as it was printed on bad printer years ago and quality is subpar.
What would be your recommendation?
I'm in a similar boat. I want to upgrade stuff because .. it's a project, but INDX is around the corner. :D Still rocking stealthburner with clockwork 1.
Galileo 2 kit and Nitehawk-36 look good, but that would mean you will throw that out again in a few month.
My idea now is either CNC parts, or 9 mm belts. There is also the option to go will 4WD or whatever it's called where you have 4 motors on the gantry. LDO makes a metal kit for it.
