- Voron 2.4
- Clockwork 1
Gents I need some advice on a Z axis home problem. Set up is BTT Manta MP8, Can Bus 2209 /2240 and tap.
Sequence
Home X
Z goes up 10mm
X goes to home through the Can Bus (no issues)
Home Y
Z goes up another 10mm
Y goes to home (no issues)
Home Z
Z goes up another 10 mm
X and Y go to center position (no issue)
z motors front left (motor 3 z0) back left (motor 5 z1) back right (motor 6 z2) all go DOWN. Now the issue, front right motor (motor 7 z3) goes UP???
Troubleshooting attempt so far.
ran STEPPER_BUZZ=stepper _z3 it only moves UP
changed cable no difference.
changed driver no difference.
any ideas would be appreciated, I have built other printers in the past but using the Duet board never BTT and Klipper. It's as though it's not getting a negative pulse.
Regards,
Mark
Sequence
Home X
Z goes up 10mm
Home Y
Home Z
Regards,
Mark
