2.4 Panel attachment clips
RichT
While I don't seem to have enough parts, the parts I do have seem different sizes so thought I'd ask before sourcing anything.
The assembly guide shows:
Back and top panels using M3x8 screws. Eight corners and seven middle clips.
Side panels using M3x12 screws. Eight corners and eight middle clips
I have only 12 corners, but the are all 7mm thick with a 3mm lip. For the middle clips I have twelve 7mm thick with the 3mm lip and five 10mm with a 4mm lip.
I'd have thought the 12mm screws went with the thicker clips but not enough of them.
Using the foam tape how many corners and middles should I have of each thickness and should I use M3x8 with the thinner and M3x12 with the thicker?
Thanks
BTW, was I supposed to wire the exhaust fan before putting the bottom panel on? I see that in a few steps on page 256 but I put the panel on in page 232. Must have missed that earlier.
I'm not sure which kit and bought a year ago from someone on Facebook who lost interest. Thanks for the link. The mix of thicker and thinner makes sense with the M8x8 vs 12 screws. I'll put together using what I have that's right. Maybe a little duct tape and once I get working my first project will be to print the ones I need.
Thanks!
