While I don't seem to have enough parts, the parts I do have seem different sizes so thought I'd ask before sourcing anything.
The assembly guide shows:
Back and top panels using M3x8 screws. Eight corners and seven middle clips.
Side panels using M3x12 screws. Eight corners and eight middle clips
I have only 12 corners, but the are all 7mm thick with a 3mm lip. For the middle clips I have twelve 7mm thick with the 3mm lip and five 10mm with a 4mm lip.
I'd have thought the 12mm screws went with the thicker clips but not enough of them.
Using the foam tape how many corners and middles should I have of each thickness and should I use M3x8 with the thinner and M3x12 with the thicker?
Thanks
Thanks
