Solved Bed and Purge Bucket Position after Low-Profile Y Endstop Install
Laserbea4k43
Voron 2.4 350
Galileo
Hello,
I've in stalled a low-profile y-endstop and transposed z-chain mod after installing an EBB 2209 USB.
After doing so, I've had to(?) physically adjust my bed location in order to get 0,0 to meet at the front-left corner of my bed, it was hanging over a bit. But also modified my steppers config like so:
Python:
[stepper_x]
##    Uncomment for 350mm build
position_endstop: 348.5
position_max: 348.5
[stepper_y]
position_endstop: 349
position_max: 349
Now, when I use my clean nozzle script, it the nozzle doesn't reach the brush, so I tried adjusting by updating the brush position as follows:
Python:
## These are only used if location_bucket_rear is False. You specify a custom location in y axis for your brush - see diagram above. ##
variable_brush_front:       357
variable_brush_depth:       377
Running the script now gives me an out of range error.
Could someone help me reconfigure?
OK,
So I realized that If i pushed the toolhead back any further, I would be hitting the endstop. So I pulled the bed back up, and changed my position_max and position endstop back to 350 on both Axis'.
Made adjustments to add 7 to the Y position, reset my scrubber script and readjusted for my new silicone version and everything is good!!
