I have a BTT EBB 2209. Intention is to use a 3 wire hotend cooling fan with the tachometer feedback to shutdown the hotend if the fan fails.
Just getting it all up and running now. I finished the mechanical and wiring yesterday.
The cooling fan is wired into the PWM output on the EBB. PWM isn't used as this is a 3 wire fan and I don't need to control that fans speed anyway.
Problem: The fan is running all the time.
The fan is reporting RPM, so that is good.
relevant config section:
Fan reports ~8700 rpm which is about correct for the fan. (8500 on the spec sheet)
[heater_fan hotend_fan]
# Hot End Fan
# Fan PWM
# max_power: 1.0
# kick_start_time: 0.5
pin: !EBBCan: PB14
tachometer_pin: ^EBBCan: PB15
tachometer_ppr: 2
heater: extruder
heater_temp: 40.0
fan_speed: 1.0Fan reports ~8700 rpm which is about correct for the fan. (8500 on the spec sheet)
