mikedkelly
I exclusively print R/C airplanes with my Voron 2.4 and would really like to use ASA due to its impact strength, temperature resistance, and slightly lower weight compared to PLA and PETG. Using Polymaker ASA at nozzle/bed temps of 240/90, my chamber reaches a passive steady state temperature of 50 degrees. However, with these single-wall, 25cm tall parts, I am still getting warping on the walls in the open areas where the infill grid is not touching. I believe I can get the chamber in the 70 degree range passively via insulation, but I am not sure if it will be enough. I don't want to invest in insulation and thicker panels if in the end it needs something more like a 100 degree chamber. Has anyone had success printing these types of parts in ASA?
