BrokenPoet
- Formbot Voron 2.4R2
- Clockwork 2
I am just finishing the build of my first Voron and have been trying to diagnose random shutdowns that predominantly occur during prints (I think I may have caught one that was not during a print as well.) My setup is as follows:
Thanks in advance!
Edit 10APR23:
Additional troubleshooting:
It's down to either a hardware issue with the Octopus, the EBB36, or a Klipper issue. Any thoughts?
- Base Formbot kit
- Orange Pi 4 LTS (Running Armbian Jammy)
- Octopus 1.1 (using the USB to CAN bridge)
- EBB36 Tap Stealthburner (CANbus)
- Checking continuity & resistance of CANBUS wiring to EBB36.
- Suspecting an EBB36 temperature related issue I mounted a cooling fan over the EBB36 - During ABS printing the EBB36 does not exceed 52C
- Lowered my running current to the EBB36 Extruder to further limit the potential for heat issues (I'm at 0.4A now - running fine)
- Suspecting an Orange Pi temperature related issue I mounted a cooling fan over the OPi - Temp does not exceed 36C during printing
- Octopus is directly behind the skirt cooling fans - temp doesn't exceed 35C
- Suspecting a USB cable issue I swapped cables (no effect) and added a ferrite core to the cable (no effect). The USB 5V jumper is removed from the Octopus so I don't think 5V passthrough could be a culprit.
- Removing the Orange Pi controlled relay to the 24V PSU and hardwiring the PSU on (just in case the relay was chattering)
- Checked output voltages of both 5V and 24V PSUs - adjusted them to slightly above their nominal voltage to rule out voltage droop (5.2V and 24.2V respectively)
- Running a 'SPEED TEST" while at temperature several times to see if it was a very intermittent cable short - no effect (but I'm not skipping steps, so I have that going for me.)
Thanks in advance!
Edit 10APR23:
- Replaced the Orange Pi 4 LTS with a Raspberry Pi 3 - Same failure mode
- Tried a brand new shielded USB cable between the Raspberry Pi and the Octopus - Same failure mode
- Replaced the CANbus umbilical with twisted pair - Same failure mode
