Enderwire Conversion (Siboor Kit)
My first printer was an Ender 3V2. I learned the ins and outs of 3D printing on it and I heavily modified it. Some of the main upgrades I did were CRTouch, PEI magnetic bed, BMG Extruder in Bowden configuration, Slice Engineering Bimetal Heatbreak with Copper Plated heat block, Gulf Robotics bed, and Creality Popup Enclosure.
My next printer was a Voron V0.2r1 kit I got from Formbot. I printed the parts on my trusty Ender and thoroughly enjoyed the process. After the V0.2 was built I found myself using it more and more mainly because of the speed at which I could print things, I only ever used my Ender for larger prints that I could not fit on the build plate of the Voron otherwise it sat idle. I was contemplating getting a 2.4 or Trident to print larger items but then I found people were converting Enders to Switchwires for significantly less money I felt like that was a perfect solution.
I went with the SIboor Kit, I looked at self sourcing because I planned on reusing a lot of my upgrades but I could not come close to price of the kit even when excluding the things I didn't need. The kit parts themselves are fairly good quality except the no-name hotend with no replaceable nozzle, I threw it in the trash. That was ok because I wanted to reuse my creality hotend with Slice heatbreak (more on this later). The directions to put it together are mediocre and not to the same standards as the official Voron manuals. A lot of times the directions would skip steps, or call out the wrong type of screws.
My Ender control board had all of its connectors hot glued on and I could not free them so I decided to use a SKR Pico like in my Voron V0.2 since I could copy a lot of the klipper config and Sibor does not supply any sort of official config to use the Ender's mainboard anyway. That was a great idea until I realized I had to re-crimp the entire wiring harness that comes with the kit, that was not fun but that one was on me.
My biggest complaint with the Sibor kit is the enclosure. If you put it together the way its meant to be you will never be able to remove it easily since it is held together almost entirely with VHB tape. I modified it so the back panel and both top panels could be removed separately and I modded the doors to use magnetic hinges so those could be removed as well.
So once I got the printer configured and working, I started tuning the print quality. I kept on hearing clicking every so often so i investigated to see if the motion system was hitting something. After awhile I realized it must be the extruder because I was getting really bad top layers when tuning the flow. I had to take apart the Stealthburner to diagnose the problem. This would have been extremely difficult had I not modified the enclosure to be able to be removed. I tuned up the CW2 got it running smoother and put it all back together but still heard the clicking. Then it dawned on me that I should probably do a a max flow test. My naive self thought that since my upgraded creality hotend was essentially the same as my dragon hotend on the V0.2 (Copper heat block, bimetal heatbreak, and same 60W heater) that I could drive the same 12-15mm/s3. Nope, the PLA+ I was trying to tune topped out at 8mm/s3 on the Enderwire at my usual temperatures. I had never experienced higher flow rates when it was an Ender because I did not drive it faster than 100mm/s. So now I'm debating on upgrading the hotend or just waiting awhile.
Anyway here are some things I take away from the conversion and the Sibor kit...
1) Do not build the Siboor kit as your first Voron experience. I know it seems like an inexpensive way to dip your toe into Vorons, but you're gonna have a bad time.
2) Modify the enclosure to be removable!
3) You will need a working 3D printer on hand because of step 2 and the instructions are not very clear on what 3D parts you need. You will re-print things.
4) Be careful with what parts you want to reuse from the old Ender, most of my headaches came from trying to reuse things.
5) With a Formbot Trident or 2.4 250x250 kit coming in at <$700, and you get premium upgrades like a screen, TAP, CAN toolhead, CB1(Rpi replacement). I don't think this conversion is worth it. I think I only did it out of nostalgia and a sunk cost fallacy if I'm being honest with myself.
Follow up to my previous post.
I was having really bad layer shifting in the Y axis only when printing larger parts. Fixing it was a combination of belt tension and changing the stepper motor current in my printer.cfg.
The kit calls for you to reuse the Y-axis motor from the Ender, but the press fit pulley was stuck too hard that I was afraid of damaging the motor, so I re-used the extruder stepper for my new Y-axis motor. This motor is a larger 42-40 and can take a max 1.0A current so I don't think I was powering it enough to overcome the inertia of the bed during large travels.
Holy crap...I just finally ordered my kit and after reading this I'm freaking out lol. I have the old Ender 3, a Prusa XL & a Bambu A1. I have never built a Voron before, so after reading this that's where my apprehension comes into play. My Ender was upgraded with a BTT Mini SKR board & I believe a Swiss Micro knock off Hot end...but that's about it. Is there any way you can share your enclosure mods? I had no idea it was secured mostly with tape, that sounds pretty insane.
For the enclosure I used some parts from Fizzystech (https://github.com/fizzystech/ft_enderwire). Other brackets that were meant to put the VHB tape on both sides I drilled holes large enough to put M3 threaded inserts on at least one side. I then drilled holes in the panels to match where I attached the brackets. I did it all rather sloppily and if I did it again I would probably copy Fizzytechs setup.
Here are the Magnetic Hinges that I used
And here is an upgrade to the motor mounts that I thought were needed
Here is the mod to keep your Creality hotend. (FYI I just used the standard M8 nozzle and the cooling seemed to work fine)
Read through some of the other Voron assembly manuals, especially the parts with the pulley assembly/alignment and belt routing to get an idea of how things work. Your Mini SKR board might be compatible with the included wire harness since its supposed to be a drop in replacement for the Ender control board.
After about a year and a half (or longer) I finally got my ender 3 pro to switchwire conversion working. Part of the reason it took so long was that I had specific plans for the printer and I deviated quite a bit from the design. I got a dual input hot end and built two mobius bowden extruders with the idea of having a dual color capable printer. I also upgraded to the SKR mini controller, but also added a BTT 2040 CAN bus tool head board. The hot end constantly clogged inside the heat break tube so I gave up the idea of dual extruders. I ordered a G2E extruder kit, and an E3D Revo Voron hot end. This worked very well, but I was getting inconstant first layers, and I blamed my problems on poor accuracy readings from the Omron inductive probe. So I got an E3D PZ coldside kit, and switched to using that as my Z probe. The PZ probe worked fine at first, but then the BTT CAN toolhead stopped communicating with the RPi. I tried a new cable, but that didn't fix the issue. Either the C2U adapter went bad, or the tool head itself. So I got a hart toolhead board and made up a 16 wire cable, and had my toolhead talk directly to the SKR mini. This worked fine, but the PZ probe kept false triggering I suspected this was an electrical noise problem, but the PZ probe would false trigger more often with the hot end heater on (and hence the hot end fan), so it could have been fan vibration. I then attempted to build a klicky probe instead of the PZ. This requires a servo to move the docking station into position, but I couldn't get the servo to give repeatable movement, it would never go to the exact same angle after a power cycle. So I went back to the Omron probe and finally discovered how to set my z offset correctly. Now the omron probe appears to be close enough, though I will have to create several profile files with different mesh and z offset settings for different build surfaces and bed temperatures (material dependant). Once I perform a bed mesh and a probe calibrate before a print, the results are good.
I've installed the enclosure panels and have a Nevermore filter in the printer. The Nevermore fans circulate the air, and the chamber can reach 50C within a half hour. Printing with ABS works great, and I can print parts for a Voron Trident on the Enderwire. In hindsight, I should have stayed "stock" on the build, however I have learned quite bit from my experiments, though it cost me a few hundred dollars more to build this printer. My Trident build is going down a similar avenue, It will have a nitehawk tool head board, a Beacon probe, and the PZ probe (though that might not get configured into klipper as the BeaconH can perform that function). It will also use the G2E, it's a better extruder than the CW2 IMHO.
p
