I just finished building and fired up my second V2.4 (but my first one with Tap).  All preliminary testing went well, tap working, and so I tried to print the voron cube for the first test print.  After initial homing, probing and QGL, etc, at 150c the print then fails because the print head is still at 150c instead of 245c (my desired print temperature).  It seems the print temperature is not being passed through and restored after the 150c phase.  I assume that should happen.  Any suggestions what I am missing?
As a side note I found the adaptive bed mesh is not working but I have not explored that. I am using the same setup as my other V2.4 and the adaptive bed mesh and adaptive purge work well there. I mention this in case it somehow relates to the above issue.
Any suggestions are appreciated.
Thank you.
P.S. Regardless I am super excited to have the second V2.4 running with Tap!!!
Thank you.
